(0)| 5/15/2025 5:09 PM | |
Joined: 5/14/2025 Last visit: 5/21/2025 Posts: 4 Rating:
Hi there, I think I have the same issue. After that update for V20 you mentioned, will be necessary to run chmod to make it run in the /home/industrial path? or won't be longer necessary. I want to run a sh file from there when I press a PB from the HMI, but nothing happens. Thank you for your time. Jonathan ------------------------------------------------------------------------------------------ |
Last edited by: Wit_Moderator at: 05/16/2025 08:54:06Neue Überschrift nach Splitten |
| 5/16/2025 7:54 AM | |
Joined: 1/21/2013 Last visit: 1/22/2026 Posts: 4427 Rating:
Hi Jonathan, Even with the V20 Update 2 image version, the scheduled task does not run with the same user privileges as the HMI processes. Therefore, to execute a script located at /home/industrial/, the group's execution privileges must be set with the chmod command. Kind regards |
