(0)| 7/4/2025 9:37 AM | |
Joined: 8/3/2009 Last visit: 1/19/2026 Posts: 16644 Rating:
Hello Wim_p do you have tried it to setup your configuration only with teh computername and without the IP? Do you have a DNS in the Network? Basically you should also be able to use the name resolution if it works in your network if you do a Client Access (Some information are also in this Link ) bye Murof |
Last edited by: Murof at: 07/04/2025 09:40:39If this Information really helps, you could use the Rate function |
