(0)| 11/21/2009 1:08 PM | |
Joined: 10/7/2005 Last visit: 1/16/2026 Posts: 3054 Rating:
Hello kthioune not too sure what exactly you mean by "when i reset them the cpu 1 and 3go torun mode,but as soon as the CPU 2goes in run mode,the3 cpu go alsointo default". Could you please give us some detail on what type of "reset" you did (e.g. power off/on OR Stop/Start of individual CPU etc.) and what you mean by "the3 cpu go alsointo default". Apart from that, there are two manuals that you should consult and which have the required info on how to do a coordianted/synchronised Multi CPU startup in an S5 which in your case are: S5-135U Programmable Controller CPU 921, CPU 922 SIMATIC S5-135U/155U System Manual I hope this helps |
Cheers |
