1/13/2010 1:56 PM | |
Joined: 9/27/2006 Last visit: 9/15/2025 Posts: 12408 Rating:
Hello BiteMe; If you have acquired the analog signal, the next step is called "scaling". This concept involves adapting the raw values read from the analog input and calculating the equivalent value on the engineering units you will use (0-10 V, in your case). Have a look at thefollowing FAQ that will show you basic stepson analog scaling: http://support.automation.siemens.com/WW/view/en/27043396 Hope this helps, Daniel Chartier |
