4/28/2010 4:41 PM | |
Joined: 3/14/2008 Last visit: 9/8/2025 Posts: 2216 Rating:
I hope i understand correctly but you try to open a faceplate from a faceplate x-times? You are using: opennexfaceplate button? If you want to call multiple faceplates, you have to work with numbers: instead of using a LOCK faceplate, you must put a number behind the name: LOCK1, LOCK2, LOCK3 Check "Process control PCS7, block programming instructions" for page 131 for exact configuration I don't know exactly I hope this is what you mean |
