(0)| 9/19/2006 8:30 AM | |
Posts: 18 Rating:
How can I do that? Can you explain. :( |
Last edited by: Stipan at: 9/19/2006 8:34 AMLast edited by: Stipan at: 9/19/2006 8:33 AM |
| 9/19/2006 8:48 AM | |
Joined: 4/24/2006 Last visit: 1/16/2026 Posts: 9105 Rating:
Hi Stipan, Here is a faq, which explains how to read out the serial number off the MMC: http://support.automation.siemens.com/WW/view/en/19215608 Best regards, Wizard |
| 9/19/2006 9:24 AM | |
Hello Stipan, You can read out the system clock off the CPU, you can also make a compare with the date you want to stop the CPU. When it match, you can STOP cpu with SFC mentioned earlier. To protect your programm: have you seen the following thread: /tf/WW/en/Posts/4831 Perhaps it is helpfull. Best regards, Wizard |
| 9/19/2006 9:44 PM | |
Joined: 9/1/2005 Last visit: 1/9/2026 Posts: 4114 Rating:
Hello, the avatar files are gif-files. Normally it should works to insert a gif-file. You can insert a smilie with clicking on an emoticon above the text field. Regards CS Moderator |
