10/14/2010 9:58 PM | |
Posts: 5 Rating:
Im having an issue implementing a text list in my HMI using the basic V10.5 I have created a list called "Status", and added several items to it: (0) - - - - - - - - (31)Disabled (1) Running (2) Stopped and several others. I have attached a screen shot showing the text list, and the symbolic IO field configuration. The problem i am having is that it does not work, regaurdless of the INTvalue i assign to the HMI tag the list always displays the default value, or nothing if a default is not selected. I have read the documentation in help and found it to be lacking: [schnippschnapp] other questions are in the following threads What is a "Bit Number". "Visible Entries" is no where to be found, where is it?. "Apply value on exit" is no where to be found, where is it?. |
Last edited by: O_Moderator at: 10/15/2010 11:06 AMLast edited by: RMueller at: 10/14/2010 10:00 PM |
10/14/2010 10:42 PM | |
Joined: 7/7/2010 Last visit: 9/9/2025 Posts: 16079 Rating:
Try changing your text list "status" from bit 0..31 to range. |
science guy |
