(0)| 10/16/2010 11:10 AM | |
Posts: 8092 Rating:
Have you checked the ohmic value of thermal sensor when you are getting high temp alarm signal. Please check it & if it is changing then it is recommended to get the motor serviced from Siemens. I am attaching the sheet for your information.
AttachmentPFK7.pdf (934 Downloads) |
| 10/16/2010 11:32 AM | |
Posts: 31 Rating:
i already replaced a new motor and power and data cable but the problem still exist. |
| 10/19/2010 5:49 AM | |
Posts: 8092 Rating:
Do you have spare control card? Pls check by replacing it. Regards, DEEP. |
