(0)| 12/30/2010 7:29 PM | |
Posts: 134 Rating:
normaly a pulse logik relay need two singals at its input for to change its state (on-off) even the latch logik relay need to receive a reset input for to be able to come in on state again. so normaly if your button still make a contakt it's not a problem. but if you dont want to warry about then you could use a timer ( delay on) which will reset the logik after a few seconds. Attachmentlwt.zip (460 Downloads) |
| 12/31/2010 9:05 AM | |
Posts: 2 Rating:
Hi cdrshort, It looks like it works. Thank you very much for your support. Cheers.
