(0)| 4/10/2012 7:36 AM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello, If I understood right you replaced the DI and DO modules with 323-1BH01-0AA0. In order to use the same addresses you should biuld a new configuration in which the addresses will be covered, at least for first I/O byte. Description of that module SIMATIC S7-300 S7-300 Automation System Module Data Best regards, Hristo Mihalev |
