(1)| 7/26/2012 11:27 AM | |
Hello, That is probably not a Siemens battery, but will do the job. The Siemens battery is mentioned in attached part of manual (battery specs too) Don't forget to put back the battery switch after replacing the battery's! You get no warning if this switch is off, no leds and also not in software if programmed. Battery partnumber Regards, Marcjan Attachmentbattery.pdf (602 Downloads) |
