(0)| 1/9/2013 2:46 PM | |
Hello selim; For such enquiries Siemens has prepared a very useful software, as a web-service: the Siemens Compatibility Tool: https://support.automation.siemens.com/kompatool/pages/main/interim.jsf The attachment shows the compatibility requirements between Windows 7 Ultimate 64-bit and Step Basic (TIA Portal) v 11.0: you require Step 7 Basic V. 11.0 SP2. If this is not the correct version of TIA Portal you are using, you can start your own compatibilty search with the tool. Here are links for updates to Step 7 (TIA Potl) v. 11.0: Service Pack 2 for STEP 7 V11 Released for Delivery Updates for STEP 7 V11 and WinCC V11 Daniel Chartier |
Joined: 8/31/2010 Last visit: 12/6/2025 Posts: 1525 Rating:
Hello selim33, You need TIA Portal v11 incl. SP2 to install in Windows 7 64 bit OS. Have a look here Service Pack 2 for STEP 7 V11 Service Pack 2 for WinCC V11 Anyhow the downloaded SP2 doesn't help you to install in a Windows 7 OS. You need a trial DVD of the same atleast to get it done. |
Like it? Rate it! |
