2/19/2013 4:51 PM | |
Posts: 10 Rating:
Hi I dont have any tags in my HMI tag Tables. However I do have Tags for outputs and inputsIn my PLC tag table. When I want to turn on one of these tags from WinCC how do I call it? For example I want to turn on amotor which in my step 7 program is output Q8.5 "Tag 4". When I try using a switch to set tag 4 it gives me a warning message. I will attachmessage On a screen grab.Please have a look and let me know what you think? Attachmentsreen grabs.pdf (680 Downloads) |
2/20/2013 3:32 PM | |
Posts: 3037 Rating:
Hello, You find the IM folder on this place where you save your project. How do you migrate tags from STEP 7 V11 to WinCC V11? Tweety |
2/21/2013 5:27 PM | |
Posts: 10 Rating:
Hi Yes I tryed migrating the tags from my plc tag table the same way it was done in your tutorial. However it cannot access these tags because it says that connection is not able to.I have deleted the IM folder and I am still using the same connection. I will attach screen grabs of the error. Please have a look and see what you think. I am using TIA portal V11 SP 1 Attachmentsreen grabs.pdf (707 Downloads) |
2/22/2013 10:55 AM | |
Posts: 3037 Rating:
Hello, You install SP2 with Update 5 for WinCC V11 and check your problem again. Service Pack 2 for WinCC V11 Updates for STEP 7 V11 SP2 and WinCC V11 SP2 Tweety |
2/26/2013 6:23 PM | |
Posts: 10 Rating:
I have downloaded sp2 and update 5. This stil left the same problem where the connection could not be made.I will attach the screen grab. The step 7 programming is uploading as it should. What else could I try to gain this connection?? I will add more screen grabs to show my project. maybe you might see my problem from this AttachmentWin CC connection.pdf (568 Downloads) |
2/27/2013 6:21 PM | |
Posts: 3037 Rating:
Hello, You can start a support request for your problem. --> support request Tweety |
