(0)| 4/5/2013 4:38 PM | |
Posts: 11 Rating:
I lave a LOGO 06 series with the standard TD display. I want to be able to set a number of values from the display, and decided that using two functionkeys in conjunction with the arrow keys would be the best way to ensure no accidental changes. In simulation, it works fine. In reality, it doesn't work at all. Any clues why? Any alternative suggestions. I would like to change 6-8 different values. Attachmentdisplay input test, forum.zip (356 Downloads) |
| 4/5/2013 5:05 PM | |
Hello, What is it that does not work? You know that you have to use the ESC key together with the arrow keys? How can you press the F1 and F2key to activate the message, the ESC key and a Cursor key same time? In simulation no problem, in real life... Have a look at the Logo application examples for a menu structure. Use password protection to avoid unwanted changes. Section Display Regards, Marcjan |
