(0)| 9/25/2014 8:23 AM | |
Joined: 1/4/2007 Last visit: 1/13/2026 Posts: 1198 Rating:
Hello Jengeese, Which Siwarex modules do you have? There are different modules with different S7- programs. Are you working with Simatic Manager or with TIA Portal? Best regards Siwarexi |
| 9/25/2014 10:21 AM | |
Posts: 84 Rating:
Hello and thanks for the quick answer sir. We are using Siwarex-U and Simatic Manager V5.5. Their communication type set to SFC, SFB, FB communication. |
| 9/25/2014 10:39 AM | |
Posts: 1525 Rating:
Hello Jengeese, its look like you have Different Project or Some one has removed the Siwarex Logic Blocks, In below Link you will find the Detail about the Programing with Step 7 & Siwarex U Getting Started S7 Project for SIWAREX U (Step 7 Classic and TIA-Portal) So in the Zip file you will find the Project & Manual for the Project in Detail. Also below Manual for the Calibrating with SiwaTool Software.... Calibrating SIWAREX U with SIWATOOL U |
| 9/25/2014 11:00 AM | |
Hello Jengeese, Ammy is absolutely right! Please take a look to Ammies links: With these links you can find the Step7 example project for the Siwarex U module in the Simatic Manager and how to do a calibration with the Siwatool software. Best regards Siwarexi |
