(0)| 3/15/2016 11:24 PM | |
Hello LuciferC4; I do not believe that you can use Ethernet connections between a PLC and Protool/Pro RT. The Ethernet interface is only valid for OPC conections. This can be found in the following manual, as seen in the attachment:
SIMATIC HMI ProTool/Pro Runtime
https://support.industry.siemens.com/cs/ww/en/view/1142578 Hope this helps, Daniel Chartier |
