(1)| 1/17/2017 2:49 PM | |
Posts: 2 Rating:
Hello! I am currently performing the tuning of the controller through a methodology based on Ziegler & Nichols and Cohen-Coon for academic purposes, however I want to know if the PID control algorithm has a serial or parallel configuration (Interactive, Noninteractive, and Parallel algorithms)? In addition, I would like to know the units in which the parameters PG, TI, TD are expressed in the PID function block. ------------------------------------------------------------------------------------------ |
Last edited by: Min_Moderator at: 1/17/2017 4:00:52 PMNew subject after splitting |
| 1/18/2017 5:31 PM | |
Posts: 623 Rating:
Hi, The attached manual may help you. AttachmentStdpid_e.pdf (644 Downloads) |
