9/18/2008 6:13 AM | |||
Joined: 9/27/2006 Last visit: 9/5/2025 Posts: 12398 Rating:
Hello simatix; Here are a few answers found on the Siemens A&D Mall site. Use the availablelinks and the Description tab wherever you find it to locate the technical information available; the configurator tab is also a good way to see more information (it allows you to build a unit by selecting different options, so you can find what is available: 1) For the PC104 expansion kit:
2) sorry, can't help you there, i haven't used ISA to PCI converters ever, either in Siemens PCs or elsewhere. In similar circumstances, we always thought it more reliable to locate a PCI (now PCI-E) card whenever we could; we've been lucky up to now I guess. 3) This link will take you to the industrial PC section of the Mall: Rack PCs, Panel PCs, Microboxes...: https://mall.automation.siemens.com/WW/guest/index.asp?display=6K&nodeID=5109999&lang=en There is also a section on Sicomp industrial microcomputers you might want to look at: https://mall.automation.siemens.com/WW/guest/index.asp?display=6k&nodeID=7009999&lang=en&foldersopen=-1426-1-4061-4129-&jumpto=4129 Hope this helps, Daniel Chartier |
