(0)| 8/9/2019 10:20 AM | |
Posts: 10 Rating:
https://support.industry.siemens.com/tf/ww/en/posts/iot-internet-access-via-pc/178047/?page=0&pageSize=10#post864792 Hello and thank you for your explanation. I need internet for my iot2020. USB don't work beacause I dont know how to install drivers. I tried this USB Stick: https://support.industry.siemens.com/tf/ww/en/posts/how-to-install-wifi-driver/218288/?page=0&pageSize=10#post864717 Now: If I follow your instructions I can't reach my iot with putty. Only when I delet the bridge i am able to conect iot with putty again. I need the ip adress of my iot which it gets from the router. How can I find out the IP adress of my iot which it gets from the router when i anable the bridge? Also internet is not available anymore when building the bridge. What are the settings I need? Pleas help. best regards. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 08/09/2019 12:02:30New subject after splitting Last edited by: JKBJHW at: 08/09/2019 12:45:58Last edited by: JKBJHW at: 08/09/2019 13:14:17 |
| 8/12/2019 3:10 PM | |
Joined: 12/12/2016 Last visit: 12/11/2025 Posts: 640 Rating:
Hello, Its an IOT2020, so you only have one ethernet interface? Does your router have dhcp activated? You could use a switch to hook everything up and check your router config or use wireshark to see which IP the IOT was assigned to. Or set a static IP in the subnet of your router and use these settings. Kind regards! |
