(2)| 2/26/2020 12:56 PM | |
Joined: 1/28/2009 Last visit: 1/5/2026 Posts: 6892 Rating:
Hello,
This is possible due to a STEP 7 compatibility issue or a problem inherited from your Operating System.For compatibility check , see if your OS and your version of STEP 7 is compatible . As SCL is a high-level language like Pascal , you can use Notpad++ to easily develop your SCL block and only import it in STEP 7 for compile and function test. I hope these points help, hdhosseini |
| 2/26/2020 6:37 PM | |
Joined: 11/14/2018 Last visit: 4/2/2025 Posts: 17 Rating:
Thank you for the tip, but I'm working with Simatic S7 manager. |
| 2/26/2020 6:51 PM | |
Joined: 9/21/2012 Last visit: 1/19/2026 Posts: 4853 Rating:
That also needs Win10 Pro or Enterprise. |
