(1)| 7/2/2020 10:24 AM | |
Joined: 11/15/2015 Last visit: 12/3/2025 Posts: 180 Rating:
Dear claude_reckinger Why you are not reading it from the rating plate (type plate) that contains the technical data relevant for the motor! Regards, AttachmentOperating Instructions, Synchronous Motors 1FK7.pdf (913 Downloads) |
Look for alternative not for the correct answer...if this is helping you rate it. |
| 7/5/2020 5:21 AM | |
Joined: 4/25/2015 Last visit: 12/27/2025 Posts: 115 Rating:
Thank You for your answer, which parameter should I read? |
| 7/6/2020 10:23 AM | |
Joined: 10/11/2006 Last visit: 1/19/2026 Posts: 6069 Rating:
Hello please have a look into Library LMoMa. There is a FB (FBLTopoDqTopologyHandling) https://support.industry.siemens.com/cs/ww/en/view/58251583 Please note: This function use Library LDPV1 https://support.industry.siemens.com/cs/ww/en/view/109479553 |
With best regards, |
