(0)| 7/18/2020 9:46 PM | |
Posts: 2 Rating:
For an upcoming project I need to use Ignition Edge IIoT from Inductive Automation. The customer requires that I publish data to a MQTT Broker with the Sparkplug B specification (Cirrus Link Chariot). I would like to use the IOT2040, but I am unsure if I will be able to install and run Ignition Edge IIoT. The requirements for Ignition Edge IIoT are (.pdf attachment with requirement on the bottom of page 2): RAM: 1024 MB HD Space: 1GB OS: Ubuntu Linux 12.04 or later Will this integration be possible? What, if any, modifications or accesories (i.e.SD card) will be required? Or would it be advisable to use a IOT2050 or Nano? Thank you! AttachmentEdge IIoT - $800.pdf (431 Downloads) |
