(0)| 8/30/2021 10:28 PM | |
Joined: 9/27/2006 Last visit: 12/31/2025 Posts: 12479 Rating:
Hello jonybe; A diagnostic LED flashing red on your module siagnifies "Module Parameterized and moduele diagnostics", which translates to: you have problems with your input and ouput IO-link devices. Whenever you have a diagnostic LED indicating a fault, the CPU's diagnostic buffer registers a coded fault message, the following link gives the description of these alarms and their code: https://support.industry.siemens.com/cs/ww/en/view/67328527/105236721163 Open the diagnostic buffer of the CPU and use this table to examine the messages linked to your IO-link master, it should be easier to understand the fault. Hope this helps, |
