4/6/2009 1:01 PM | |
Posts: 3 Rating:
Hello. Thank UMENCHO Panel is work=)..work.. But this is OP 30/C panel. I has mistake. I have in my ComGraph(v2.0) also OP30A,OP30B but not OP30C What version of ComGraph I need? And how step-by-step upload program with Com graph from OP30C? And what type of cable I need? Thank for answers |
4/6/2009 2:47 PM | |
Joined: 3/21/2006 Last visit: 3/30/2025 Posts: 10239 Rating:
Hello Alik, About OP30C - I think you would need from ComGraph v2.31. But, I am afraid that this is not possible to find it. It's very, very old software. Look at http://support.automation.siemens.com/WW/view/en/4292777 Or...
I'll try to find this version in my ways, and if I found let you know. So let's assume that you have this software. I think procedure for this "C" panel is the same like "A" or "B" types. Just connect to panel, double click on OFFLINE filed and if everything is OK then this label should be change to ONLINE. After just go to F2 Transfer and push button CP/OP-->FD. The cable is the same like Step5 and other COMs from there. Hope this will helps. Best regards |
