4/13/2023 11:49 AM | |
Joined: 5/6/2022 Last visit: 9/9/2025 Posts: 589 Rating:
Hi crmatus, According to what you describe in the post, in principle an S7-1200 would be sufficient for the type of application you describe. For the matter of readings from a PT100 you could use the RTD module of the S7-1200: "6ES7231-5PD32-0XB0: S7-1200, analog Input SM 1231 RTD, 4 AI" Finally, for more information about configuration, wiring and so on, you can check the following manual that may be of your interest: "SIMATIC S7 S7-1200 Programmable controller" I hope you find useful this information. Best regards! |
