(0)| 6/20/2024 1:32 PM | |
Joined: 12/26/2012 Last visit: 11/18/2025 Posts: 4 Rating:
In the LAN network of the PLC I can access the Siemens PLCs and HMIs via the CP1543-1, I believe because they support S7Routing. While I cannot connect to an Industrial PC with Wincc Runtime Advanced V17 installed. I am considering using IP Forwarding following the instructions in the following slide. In your opinion, is the CP's IP address 10.10.0.1 correct in the slide...? ------------------------------------------------------------------------------------------ AttachmentIP Forwarding CP1543-1.pdf (556 Downloads) |
Last edited by: Jen_Moderator at: 06/21/2024 09:02:39New subject after splitting |
