4/10/2025 12:58 PM | |
Joined: 8/3/2009 Last visit: 9/10/2025 Posts: 16386 Rating:
Hello which TIA Portal Version do you use? You can update the you Panel (TP900 Comfort) to the newest OS Version V17.0.0.8 you can use the PIU Updater for installing the image version in your TIA portal. Then do a OS Update and transfer for the Project again: https://support.industry.siemens.com/cs/de/en/view/109825750 Bye Murof |
