12/21/2010 2:26 AM | |
Joined: 10/7/2005 Last visit: 9/3/2025 Posts: 3049 Rating:
Hello Its a Sign, Its a Sign the general way of integrating a WinCC flexible HMI project into Step 7 are described in the FAQ below: How do you integrate a WinCC flexible project in STEP 7? I can't tell you though why you are unable to select a TP177B from the <Insert new Object> <Simatic HMI Station> list as it is available in my installation (Step 7 V5.4 SP5 & WinCC flex 2008 SP2). It may be an installation issue and the above link also has more info on how to fix this. I hope this helps |
Cheers |
12/29/2010 7:03 AM | |
Joined: 3/21/2006 Last visit: 3/30/2025 Posts: 10239 Rating:
Hello, Yes, you can backup this project on a MMC. I suggest you even to do this How do you save a STEP 7 project as read-protected on an MMC in an S7-300 CPU?
Of course if you have enough memory... Merry Christmas! Best regards, Hristo Mihalev |
