9/26/2011 1:29 PM | |
Posts: 270 Rating:
Hello Tibor.D, I am not sure if this would be of any help or not as I can't tell you that I tried thispersonaly norwith WinCC Flexible, but from what I've heard from a friend while ago, you should be able to installversions 2005 and 2008 alongif you name the instances of those programs differently as well as run the database for wincc flexible in compatibility mode and one of those ways might perhaps work for you. I think those questions/answers cover those bases (but generaly speaking, not related to SIEMENS products (which might render those solutions completely useless)): http://stackoverflow.com/questions/146970/can-sqlexpress-2005-and-2008-be-installed-on-same-machine-without-issue http://stackoverflow.com/questions/7535/sql-server-2008-compatibility-with-sql-server-2005 |
10/4/2011 4:13 PM | |
Joined: 4/29/2010 Last visit: 1/20/2025 Posts: 1557 Rating:
Hello, maybe it would be the best to contact the technical support and ask about this constelation...if it is realeased or not, and what can be done to fix your problem. It think this will be the fastest way to get a solution in this case. Support Request best regards |
