1/20/2012 12:32 PM | |
Posts: 165 Rating:
hi to all If you want to read/write the data from Wincc flexible to csv format , please refer the following link.. downloadtheWinccprogram from this link and run it in your wincc RT... after the program execution ,you can see the "textfile.txt" in your C: drive.... http://support.automation.siemens.com/NL/llisapi.dll?func=cslib.csinfo&objId=26106419&nodeid0=16502685&load=treecontent&lang=nl&siteid=cseus&aktprim=0&objaction=csview&extranet=standard&viewreg=NL program and pdf file: Read_Write_Data_from_or_into_a_file_PC.zip WinCC_flexible_Quellcodes_PC.zip Regards Mothilal |
