3/5/2013 6:53 PM | |
Posts: 8946 Rating:
What OS do you use? Are you logged in as administrator? |
3/5/2013 7:10 PM | |
Joined: 3/21/2006 Last visit: 3/30/2025 Posts: 10239 Rating:
Did you extract in separate folder the SP2 setup before execute it? |
3/6/2013 12:14 PM | |
Hello, I guess the installation is not done properly or there, because of errors the installation has been restareted and finally the process has not been finished corectly. Try to reinstall the WinCC Flex but with deleting all the associated folders likeHow do you uninstall WinCC flexible 2004? Another point - you have WinCC FLex 2008 software. This software is compatible with XP Proffessional SP2 or SP3 only. Not with Win7. The SP2 which you downloaded is not OK for installation of WIn7 because of
Best regards, Hristo Mihalev
