12/14/2015 2:36 PM | |
Joined: 4/23/2014 Last visit: 11/2/2023 Posts: 41 Rating:
Before modifying your UDT, you can go online, right click on the DB you want to save, and make a caption of the current values. Then you can set the caption as start value of the DB (not sure if I'm clear). After that when modifying your UDT, your DB will be reinialized to start values, which will be your current values. Edit: here is a sample of the TIA 11 manual to do this (still works with TIA 13 SP1): https://support.industry.siemens.com/cs/mdm/57185407?c=28725619595&lc=en-WW And a Pegaia's post : |
Last edited by: hl123456 at: 12/14/2015 2:39:52 PMLast edited by: hl123456 at: 12/14/2015 2:41:01 PM |
12/14/2015 3:59 PM | |
Posts: 3 Rating:
Great! Thanks a lot for your reply!! |
