10/10/2014 12:35 AM | |
Posts: 5 Rating:
Hi Marcjan, I am reading the data using %IWXXX which matches with the module IO address configuration, and my wiring is exactly the same as yours.
10/10/2014 2:44 AM | |
Posts: 5 Rating:
Found the problem. The analog module address is out side of the process image input range. Wish TIA could at least give me a warning for that |
10/11/2014 1:19 PM | |
Posts: 5 Rating:
Yes, problem solved as I stated in my previous reply. |
1/15/2020 11:35 PM | |
Posts: 1 Rating:
Hola, tengo el mismo problema. Como lo solucionó? |
1/16/2020 1:09 AM | |
Joined: 9/27/2006 Last visit: 9/17/2025 Posts: 12411 Rating:
Trabslation from the Spanish message:
Hola carlos El foro de Siemens reúne a participantes del mundo entero, y muchos no entienden español. Hemos elegido el inglés para nuestros intercambios para facilitar la comprensión de las preguntas y respuestas por todos. Por favor escríbanos en inglés en su próxima visita. Puedes utilisar a Google Translate si el ingles es dificil para ti, es un software traductor muy bueno. Para esta primera pregunta, la respuesta se traducirá al español: Lima9052 vio que la dirección que intentaba alcanzar estaba fuera de la tabla de imagenes de la CPU, y utilizó el esquema de direccionamiento periférico del TIA Portal: IWxx: P. Donde y cuando se necesita el directionamiento de la periferia? https://support.industry.siemens.com/cs/co/es/view/18325417 Hello Carlos; The Siemens forum brings together participants from the whole world, and many do not understand Spanish. We have chosen English or our exchanges, to make understanding questions and replies easier for everyone. Please write to us in English on your next visit. You can use Google translate if English is difficult, it is a very good translation software. For this first question, th reply will be translated to Spanish: Lima9052 saw that the address he was trying to reach was outside the image table of the CPU, and used the periphery addressing scheme of TIA Portal: IWxx:P. Where and when do you need peripheral addressing? https://support.industry.siemens.com/cs/co/en/view/18325417 Hope this helps, Daniel Chartier |
Last edited by: dchartier at: 01/16/2020 02:23:35Last edited by: dchartier at: 01/16/2020 02:25:01 |
