4/29/2020 5:36 PM | |
Posts: 2964 Rating:
Hello, Normally this should happen with factory rest itself. however you can also clear it by the rotary switch which is there on the NCU 7xx.x the NCU has two rotary switches in the lower section in front panel. NCK commissioning switch PLC mode selector switch please find the attached steps and may be this can solve your problem. AttachmentNC PLC clearing steps in 840DSL.pdf (111 Downloads) |
