11/4/2020 12:23 AM | |
Posts: 1 Rating:
Hi, I run the latest image 2.6.1 which contains node v8.16. Can I update Node-RED to the latest (1.2.2) version or will it fail and only run an older version because of the outdated node.js version? What is the latest versio n of Node-RED I could use with node.js 8.16? Thanks, Mandy ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 11/04/2020 10:21:07New subject after splitting |
11/4/2020 10:34 AM | |
Joined: 4/28/2015 Last visit: 3/12/2025 Posts: 578 Rating:
A new release is work-in-progress, including Node-Red update. Please have a look at https://github.com/siemens/meta-iot2000/commits/jan/dunfell-fixes. |
11/4/2020 11:12 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, seems that the current version V1.2.2 is working. After having updated it with
you need to change the startup script as described here. Best regards! |
