11/6/2020 10:31 PM | |
Joined: 9/27/2006 Last visit: 9/6/2025 Posts: 12399 Rating:
Hello MPBusuttil; You can select either Step 7 v5.x or Step 7 Professional v1x to program your S7-315-2DP, depending on your familiarity. Step 7 v1x links directly with the WinCC Basic program you will develop for the KTP panel. The process of reading tags and messages between the 2 units is very simple. To connect a CPU programmed in Step 7 v5.x to a panel programmed with WinCC Basic v1x, you will need to use the PLC as a "Device Proxy", the concept is explained in this document. https://support.industry.siemens.com/cs/ww/en/view/73502293 Hope this helps, |
