11/23/2011 8:04 AM | |
Hello, This module is for 4-wire sensors, if you want to use a 2 wire sensor you have to power the loop by an external power supply.
2/7/2021 10:08 AM | |
Joined: 4/2/2016 Last visit: 7/13/2022 Posts: 413 Rating:
Did I understand you correctly that the jumper should be between 6 and 7? what about Step7? should also be chosen 2DMU (current, 2-wire transmitter)? this module does not have a module power terminal L+, whether the input can be active (send voltage and receive signal)? |
