10/22/2017 3:42 PM | |
Joined: 1/28/2009 Last visit: 8/31/2025 Posts: 6874 Rating:
Dear user,
Module "6ES7 331-1KF02-0AB0" is an analog input while you talk about an analog output module.This is what 331 suggests in its order code. Anyway, consider you work on an analog output from S7-300 modules ,I suggest you a test for checking module.I suggest a simple check to be sure if your Analog output module is configured as you planned.
I have no comment for your program ,but if the previous step is OK move to the next and use FC106. I hope it helps, hdhosseini |
2 thankful Users |
