(0)| 2/24/2009 2:50 PM | |
Joined: 3/21/2006 Last visit: 1/10/2026 Posts: 10247 Rating:
Hello Look at Timer programming as parameterizable subroutine in STEP 7 MicroWin32. Hope this will helps a little. regards |
Last edited by: UMENCHO at: 2/24/2009 2:54 PMLook also at http://www.s7-200.net/libraries/Scripts/entryd08e.html?entry_ID=27&Part=3 . Very nice example. Not exactly for your case but I think would be usefull. |
Posts: 22 Rating:
Dear Robster Many thanks for your assistant. Yours |
| 2/24/2009 2:52 PM | |
Posts: 22 Rating:
Dear UMENCHO By move i mena: if i am in Network 5 and i need to go to network 4 or 3 by exemple to increment a variable. Many thanks for your assistant |
| 2/24/2009 3:29 PM | |
Posts: 22 Rating:
Dear Robster please check it if you can and i wait for your advice. Yours AttachmentTimer_6_hours.zip (314 Downloads) |
| 2/25/2009 9:06 AM | |
Posts: 22 Rating:
Dear All I need a clarfication regarding the using of the timers: -in total i have only 152 timers (100 ms) in S7-200(CPU 224), so i have to be carful when i use the timers,somebody tell me that we can make timers by using the SM2.2 so how? - i downloaded the timersprogrem" 10 ms timers the TON_P timer" from this site, it seems they dont use any internal timers , and is there possibilty to use this timer for my applicaionts(i have to use the timers many times , so is it correct to call this subroutine every time i need a timer 0?? please advice AttachmentMore 10msec Timers.zip (264 Downloads) |
