1/18/2022 2:53 PM | |
Joined: 8/3/2009 Last visit: 9/10/2025 Posts: 16373 Rating:
Hello TinAungKhine The systemfunction "SetDeviceMode" has as Parameter 3 possible values. So a boolean value for this parameter for dynamisation is not suitable and so its an error while compiling. https://support.industry.siemens.com/cs/ww/en/view/109798671/103456863499 Do not use a boolean Tag. If it worked with older Versions perhaps the function of the systemfunction has changed. Bye Murof |
Last edited by: Murof at: 01/18/2022 14:54:17If this Information really helps, you could use the Rate function |
