(0)| 4/12/2022 3:07 PM | |
Hello lvjn; To develop and test the WinCC v17 Advanced application, you need a WinCC v17 Advanced Engineering license. To actually run the WinCC project on a runtime PC, connected to PLCs, you need a WinCC v17 Advanced Runtime license. This type of license comes with a number of integrated Power Tags, or external tags from the connected PLCs. The screenshot below shows the part number for the WinCC v17 Advanced Runtime license with 2048 PowerTags; Depending on the size of your project, you can work with runtime licenses with 128, 512, 2048 4096, 8192 or 16384 Power Tags. The art numbers for these runtime licenses cn be found in this link to the Siemens Industry Mall: https://mall.industry.siemens.com/mall/en/ca/Catalog/Products/10360577?tree=CatalogTree Hope this helps, Daniel Chartier |
| 4/12/2022 3:30 PM | |
Joined: 6/30/2021 Last visit: 1/6/2026 Posts: 6 Rating:
does not appear for me |
| 4/13/2022 12:28 PM | |
Joined: 8/3/2009 Last visit: 1/19/2026 Posts: 16644 Rating:
Hello lvjn Here you will find a Excel list with Ordering Data where you can find all needed Information about ordernumbers: https://support.industry.siemens.com/cs/de/en/view/109795525 Bye Murof |
| 4/13/2022 1:20 PM | |
Thank you very much Murof |
| 4/13/2022 7:21 PM | |
Do you have a video explaining how to install the license? and how is it, through physical or virtual? |
| 4/17/2022 1:36 AM | |
Hello Lyin; I do not have a video, although there should be some on Youtube. What I can propose is the pdf from this document: https://support.industry.siemens.com/cs/us/en/view/74796111 On page 9 of the pdf there is a link explaining how to handle downloadable licenses. And in Murof's Excel file, for every license there are 2 part numbers, either Download (online download) or Package (USB key). Choose the format you prefer and read the link proposed earlier if you want the downloadable download version. Hope this gelps, |
| 4/22/2022 10:14 AM | |
Hello Ivjn if you use OSD then there is a manual for using: https://support.industry.siemens.com/cs/de/en/view/109479521 If you have the license in your ALM then just transfer it by using a USB Pen Bye Murof |
