(0)| 9/13/2022 4:27 PM | |
Posts: 44 Rating:
I am using the Communication Between a Beckhoff PLC and a Comfort Panel via OPC UA to setup coms with a Beckhoff OPC UA server and a comfort panel. I have the server working and it test good with the Beckhoff Simple client. In portal I can find the server when setting up the connection and I select the none/none security. When I go to add a tag and try to browse the server it disables the screen which makes me think it has disconnected. I get an error to Restart Address editor. Is this a security setting problem or a problem in portal. Portal V14 SP1 |
