(0)| 12/5/2022 10:34 AM | |
Posts: 221 Rating:
how to use html browser with ktp 700 hmi. i tried to add the html browser to the screen and run the simulator but nothing happened. |
| 12/13/2022 2:34 PM | |
Joined: 8/3/2009 Last visit: 1/22/2026 Posts: 16658 Rating:
Hello engco the htmls browser control for this panels are limited and only made for showing simple html pages. In the simulation the control will nto work identical as on the panel hw itself. So it will not give you any results if it works in simulation. you have to test it on real HW to know if it works. And you have to work also with the correct filepaths like: https://support.industry.siemens.com/cs/de/en/view/109478617 or https://support.industry.siemens.com/cs/de/en/view/109482823 Bye Murof |
Last edited by: Murof at: 12/13/2022 14:35:08If this Information really helps, you could use the Rate function |
