(1)| 4/6/2023 4:13 PM | |
Joined: 7/19/2010 Last visit: 1/4/2026 Posts: 54 Rating:
Hi Saba Jey, You can try use VBScript to send text messages: Dim appOutlook 'As OUTLOOK.APPLICATION Dim mlNewMail 'As MailItem Const addressee = "your-email-address goes here" ' Text to be sent Set appOutlook = CreateObject("OUTLOOK.APPLICATION")
This code example is from this post: The question now is how can i send email using wincc flexible 2008 Best Regards!!! |
Esdras Lopes Cardoso |
| 4/20/2023 8:31 AM | |
Joined: 8/3/2009 Last visit: 1/22/2026 Posts: 16654 Rating:
Hello Saba Jey Here also a complete solution is offered for all WinCC V7 and WincC Prof systems: https://alarm-it-factory.de/en/alarm-control-center-2/ Bye Murof |
