(2)| 5/30/2023 12:29 PM | |
Joined: 5/30/2022 Last visit: 1/20/2026 Posts: 634 Rating:
Hi v.boue, I recommend to check this FAQ: What can you do if the WebNavigator or DataMonitor client does not connect to the server? |
If this information really helps, you could use the Rate function. |
| 5/30/2023 1:45 PM | |
Joined: 2/17/2020 Last visit: 1/21/2026 Posts: 1251 Rating:
Hi, In addition to the mentioned FAQ, maybe you can check for the following possible causes: - If you are using encrypted communication (https) and a Windows server operating system, make sure that "Do not save encrypted pages to disk" is deactivated in the Internet Explorer settings (Tools > Internet Options > Advanced > Security / Tools > Internet Options > Advanced > Security > "Do not save encrypted pages to disk"). - Erroneous group policies. See FAQ: "Exceptions for hardening measures according to CIS" - Incorrect permissions for the screen or the "Web Navigator" folder. If necessary, delete the folder in the project directory and republish the images. The Security Controller should also be re-executed. - Problems with the IIS/WebNavigator Server. Try accessing directly locally, on the Web Server itself. |
A rating will be well appreciated. |
| 5/30/2023 2:34 PM | |
Joined: 3/30/2017 Last visit: 11/17/2025 Posts: 6 Rating:
Thanks for your quick feedback, I changed the internet explorer setting to make it work. |
