7/4/2023 8:03 AM | |
Joined: 5/20/2015 Last visit: 5/30/2024 Posts: 7 Rating:
Hello Experts, the Installation is getting skipped it seems [snip]
AttachmentFiles.zip (257 Downloads) |
Last edited by: Jen_Moderator at: 07/04/2023 11:34:38Log attached as .txt file. All files added as .zip file. |
7/4/2023 9:52 AM | |
Joined: 5/6/2022 Last visit: 7/10/2025 Posts: 589 Rating:
Hi int3rnal, From what I can see, it is possible that the problem is in the compatibility between the operating system Windows 11 Pro with the version of TIA Portal V16. Probably the environment is not compatible, and the installation fails for random reasons. The first thing I recommend is that you check this compatibility with the free tool from Siemens 'Compatibility Tool'. Best regards! |
