10/19/2023 1:40 PM | |
Joined: 4/28/2015 Last visit: 2/7/2024 Posts: 10533 Rating:
Hello, ok. Some first study materials are here. My attachment shows probably your exactly expected printer specification and my tips. Next is some search result from Search about S7-1200 and CM1241 communication problematic: Search results Forum about S7-1200 and CM1241 serial communication Next what I recommend is check some good ASCII table on web, you'll need this with your project. Next recommendatrion is check on PLC system manual about CM1241 serial port pins and check some informations about cables used for serial data exchange. It is possible that inside that Result of search you can find some FAQ or other users project where some typical communiaction task is described. This Forum si full of Topics with this problematic and also FAQs from Siemens. Here is also link to your printer support page where also other useful SW are, especially I expect that Tool with some exact view of tickets preparation is very interesting and can be useful to you generally. maybe there is also some option inside to see exact ESC char/byte sequence what you need send out of your CM serial port to print that |
Last edited by: Duris_I at: 10/19/2023 13:41:47Last edited by: Duris_I at: 10/19/2023 13:43:45Last edited by: Duris_I at: 10/19/2023 14:06:21Last edited by: Duris_I at: 10/19/2023 14:08:03Last edited by: Duris_I at: 10/19/2023 14:55:15With best regards... |
