(0)| 10/19/2023 2:51 AM | |
Joined: 5/30/2023 Last visit: 1/10/2026 Posts: 54 Rating:
Hello, I was just looking for standard blocks or at least a general guide of how to construct the most basic blocks (valves, simple motor, etc...) with things to take account of. So I found this Library of Basic Processes (LBP) V2.7 for TIA Portal V17 and it seems very well programmed. But when I look at the simple motor,for example, I can't figure out where to "wire" a PTC signal for error, an inductive sensor for rotation control to turn off the motor again if the shaft is not spinning, limit switches, etc. I'm not saying it can't be done with these blocks but it seems like I have to do it separately. Not asking precisely for the solution for this particular case but I'd like to be capable of modifying the block to adapt it to my specific requirements, but I'm unable to find a Siemens or a another guide online that can clear my doubts. So I hope my question is clear and someone could help me on this topic. Regards. |
| 10/19/2023 4:10 PM | |
Joined: 7/7/2010 Last visit: 1/16/2026 Posts: 16379 Rating:
When you double-click on the motor FB from the LBP, what happens? Are you not able to see the internal logic and FB interface?
science guy |
| 10/31/2023 8:08 PM | |
Joined: 3/30/2020 Last visit: 12/11/2025 Posts: 5656 Rating:
The libraries that Siemens publish in recent times is built around some programming and style guides. You can find these here: [LINK: Programming Guidelines and Programming Styleguide for SIMATIC S7-1200 and S7-1500 and WinCC (TIA Portal)] There is also the concept of standardization that plays a role. [LINK: Guide to Standardization] These links are not specifically helpful on how to build a control block for valves / motors. But honestly it is not possible to tell you what should be contained. As you demonstrated yourself, the blocks provided by Siemens already does not have what you need. Be careful to try and build a block that is a cure-all. The first generation of blocks would be far from handling every scenario. Later generation may be closer but you may still have various versions. Do these thoughts help you move forward? If not - where are the doubts? Additionally for your consideration: [LINK: Siemens Open Library] |
Last edited by: qwazee at: 10/31/2023 20:10:51Activities of this user is voluntary. There is no obligation or liability placed on this user. Though optional, your 'please' and 'thank you' is highly valued. |
