(0)| 2/9/2024 3:07 PM | |
Joined: 5/6/2022 Last visit: 1/15/2026 Posts: 589 Rating:
Hi Ced70v, Yes, safety communication can be made through PN/PN Coupler. I leave you here the information where it is commented so that you can review it: I hope this information helps you! Best regards! |
| 2/9/2024 3:14 PM | |
Joined: 7/19/2022 Last visit: 1/14/2026 Posts: 436 Rating:
Hello Ced70v, Another option is to implement an IO Controller and I-Device communication between the two CPUs. The transfer areas can be safety data and each CPU can be in different projects. In the following link in the document "Safety-Related IO Controller-I-Device Communication" you can find an example of implementing what I indicated on page 11: Configuration and Application of the PROFINET I-Device Function |
