6/15/2009 12:45 PM | |
Joined: 3/21/2006 Last visit: 10/7/2024 Posts: 10229 Rating: (1181) |
Hi, About firmware of CP look at New firmware V 5.0 for CP 343-1 TCP, new release 7 What is the status of SEND block? Do you use it? Is it possible to change type of data that you'll exchange? Just try to receive one byte. Regards Hristo Mihalev |
6/18/2009 11:26 AM | |
Hi again, So, now situation is clearer.
Unfortunately you'll need older version of Step7 or NCM. There you'll find version of FC6(RECV) compatible with this older CP. For more info look at http://support.automation.siemens.com/CN/view/en/30335356 . I don't know, but might be possible if you find this library (someone here could helps) and then just to add into existing ones. Other way is to buy new CP. Hope this will helps. Best regards Hristo MIhalev |
